ARLO PRO 2 PIR cover broken
Found that the black cover on the PIR ( black plastic is cracked). I suspect one of the builders men who were renovating the house, might have accidently knocked it off.
Is there anyway i can just replace the black piece? The camera is working fine.
There are no user-replaceable parts other than the battery. You can try some sealant (a very small amount) to see if that works and allows proper detection or maybe open a case with support to see if the camera can be swapped:
