ANY IDEALS ON SETTING UP STARLINK
HOW DID OTHERS SETUP PRO 2 CAMERAS WITH STARLINK? BOX DIDNT HAVE ROUTER CONNECTION ON NEW BOX FROM STARLINK.
I believe you need to purchase a Ethernet adapter from starlink’s store.
Some (not all) starlink customers have reported that they also either need to purchase an ethernet crossover cable, or put a small switch between the starlink adapter and the hub. If you run into that, I suggest getting a switch - it is more flexible, and you don't need to worry about mixing up the crossover cable with normal ethernet cables.
An alternative to the Starlink ethernet adapter is to get a wifi extender with ethernet out, and then pair the extender with the Starlink wifi.
