3 Activity Zones set not capturing motion videos
We are not picking up motion and when we make changes it says we must be connected to AC power which we don't have a we are tied to solar? Any solutions. Can't take it in the house as our zones would not make sense?
If not on AC power, you need to subscribe to Arlo Smart for zones to be available.
I don’t recall anyone being able to successfully use three basic activity zones at a time. Have you tried using the smart activity zone with your subscription?
Regarding the error saying it needs to be connected to power, have you tried resyncing with external power applied? This is a requirement for both smart and basic zones.
I would like to help test but every time I use activity zones it corrupts all my system settings.
So my Subscription is Smart Premier.
If I did not have this subscription, i could only setup activity zones on plugged in camera.
Since I have Premier, I can setup up to 3 activity zones on all cameras, even those not on AC power.
On the cameras on this base station, I have 5 cameras, 1 with AC power, 4 on battery.
On 2 cameras, i have 1 activity zone defined, on 2 cameras I had 2 activity zones defined and on one camera I have 3 activity zones defined. On all cameras, except the one with 3 zones defined, the camera is working fine, no issues in detecting motion, or reporting motion, or capturing video on motion. The only camera with problem is the one with 3 zones. If i reduce to 2 zones, everything works fine. If I add a 3rd zone, nothing is reported or captured. Only with less then 3 does it work. If I did not have the right subscription, I could not define any zones... the problem is with 3 zones. Has anyone ever had 3 zones work and detect and report motion and capture video? I tried this with two cameras with same result, if 3 zones no capture or report, but with 2 zones or less capture and report works fine. This is not a subscription problem, it is activity zone problem.
this is what my subscription allows:
Up to 10 cameras and 30 days of video playback.
Enhanced Notifications
Person Detection
e911 (Available only in US)
I had to get Premier plan to use activity zones on non-AC powered cameras. Purchased when the premier was on 40% off special.
“The Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community. @ShayneS”
https://community.arlo.com/t5/Arlo-Smart/3-Activity-Zones-Causes-The-Cameras-To-Stop-Recording/td-p/...
