Hi All,
Can you help me with, if should use an external hard drive or a USB flash drive for 24/7 recording.
Any suggestion on the best brand for durability.
Thanks.
@Bantum5 wrote:
Hi All,
Thanks.
You can NOT use a speed stick or hard drive for 24/7 recording.... the backup usb port will only record Triggered events of motion.
If you want 24/7 then you must purchase the CVR plan and it is cloud based.
@Bantum5 wrote:
Hi All,
Thanks.
Thanks.
All cameras connected to the base, yes. You can have multiple bases and cameras connected to those so oly the cameras connected to a base can be recorded on that base.
