1080p support
  • 5 Replies
  • 4659 Views
KurtICT
I was not impressed with video on Arlo Pro, so added an Arlo Pro 2 camera. The video doesn't seem any better. Do I need the base station for Arlo pro 2 to get 1080p?
5 REPLIES 5
Johnny290
Mentor
Mentor
No you do not
If you want 1080 recording, be sure to select Best video in Settings, My Devices, your camera, Video Settings.
KurtICT
I did that, but the picture still doesn't look much better.
The difference isn't going to be huge - you're going from ~1megapixel reolution to 2 megapixels, and then it still gets compressed. Location/positioning may be part of this since trying to take a large view with the camera just makes everything smaller. Be sure to concentrate the camera view on what's really important.
steve_t
Master Master
I also didn't find the image looked much better, especially when you see the compression artifacts, but then I did a side by side comparison in my driveway and watched cars coming and going and looked at the point at where the number plate became unreadable. The Pro 2 definitely resolves the number plate clearly at a greater distance. The visible effect of the 1080 resolution is also decreased by the fact that the Pro 2 as a wider FOV
  • 5 Replies
  • 4660 Views
