1 out of 4 Arlo pro 2 camera stopped working and went offline. Tried factory reset.
  • 1 Reply
  • 681 Views
Naot
My camera just stopped working today and went offline. The other 4 cameras are still operational. I attempted to take out battery, wait more than 15 seconds before plug it back in. The front blue light went solid for a few seconds. When plug in the USB cable, the blue light blinks a few times. I attempted factory reset by holding sync button for more than 15 seconds ; however, no amber light showed up. The camera does not give any respond at all. Please help.
There's really no reset on the Pro2 cam...
Other than pulling the battery for a few seconds.
Pull battery, after 10 sec replace.  The cam led should flash blue once.
Press base sync button and then press the camera sync button while within 3 ft of base
Base led should blink, camera will flash fast blue if the sync is good.
  • 1 Reply
  • 682 Views
