Multiple hubs or no hub
My hub is in the middle of my house and doesn't provide strong enough signal to 2 of my cameras which causes the battery to drain quickly. Is it possible to add additional hubs to extend the signal? Or can I connect the cameras to my existing wifi network as i have several Google nest wifi pods (mesh network) throughout my house?
View Entire Topic
It is absolutely possible to add an additional base station or SmartHub to allow for optimal connectivity. There is no limit to how many base stations or SmartHubs you can have on your account.
Some Arlo cameras have the ability to connect directly to your home WiFi network, but not all. You would need to check the features of your specific camera model to determine if that is an option.
