The amount of cameras supported on your Arlo account is unlimited with or without an Arlo Secure plan.
While you may add an unlimited amount of cameras to your Arlo account, you must also meet minimum requirements with bandwidth use measured on a per-camera basis.
You can live stream up to fifteen (15) Arlo cameras at the same time on the Arlo Secure App, or five (5) on my.arlo.com, depending on your system setup.
Last Updated:12/17/2024
Article ID: 1108731
