How does Arlo Geofencing work and how do I set it up?
This article applies to:
This article is for the Arlo Secure App with Library. If you have the Arlo Secure App with Feed, visit: What are Arrive/Leave Automations and how do I set it up for my Arlo system?
Geofencing is a virtual fence that helps to discover when something or someone enters or exits a pre-defined zone. You can use Arlo Geofencing to arm, disarm, or resume schedule modes when your mobile device is In Zone or Out of Zone.
To configure your mobile device for accurate geofencing:
  1. Enable GPS or location services so that Arlo can locate your device. Location is required
  2. Enable Wi-Fi.
By default, your Android device enables the overall location service, though you need to grant permission to each app you install.
If location services have been turned off for your Android device:
  1. Open Settings and tap Location.
  2. If it's off, turn on Use location by swiping the button to the right.
If location services have been disabled for your iOS device:
  1. Open Settings, then tap Privacy.
  2. At the top of the page, tap Location Services and, if disabled, turn it on by swiping the button to the right.
To set up geofencing:
Note: As you go through the Arlo Secure App instructions, the geofencing wizard displays various prompts. Tap OK, got it or Don't show this message again as you move through the steps.
  1. Launch the Arlo Secure App on your device.
  2. Tap Mode > preferred Arlo device > Geofencing.
    The Arlo Secure App Would Like to Use your Location prompt displays.
  3. Tap OK or Allow.
    If you are using an Apple device with iOS 13 or newer, you will receive another prompt later, when you are not actively using the app. You will need to tap Change to Always Allow to keep your Geofencing preferences running at all times.
    Note: Geofencing works only if Arlo can locate your mobile device.
  4. Tap the Address fieldtype the address location that you want your geofence to center around, and tap Next.
    The geofence radius displays as Medium.
  5. To change your radius setting, tap the radius icon, select a radius size, and tap Next. Radius size options are SmallMedium, or Large.
  6. Enter a name for your location and tap Next.
  7. Select an Away mode and tap Next.
    Note: When your mobile device is Out of Zone, the Arlo device defaults to the Away Mode. Most people select Armed or Custom Mode while they are away.
  8. Select a Home mode and tap Next.
    Note: When your mobile device is In Zone, the Arlo device defaults to Home Mode. Most people select Disarmed or Custom Mode while they are home.
    If you have more than one enabled mobile device, you might be asked to select an Arlo device to connect it to.
  9. (Optional) Tap the preferred mobile device and tap Next.
  10. Tap Save.
  11. Tap Finish.
  12. Geofencing has been set up on your Arlo device.
    To learn more about geofencing, visit: How accurate is geofencing?
Last Updated:11/29/2022 | Article ID: 1085093
Was this article helpful?
image description Yes image description No
Arlo Community
Learn from other Arlo users like you and experts that are offering up best practices and answering some common questions. Get involved and suggest your own topics to discuss as well.
Ask the Community
Contact Us
Have additional questions? Try our live chat or give us a call. Our team of Arlo experts is ready to answer your questions and help in any way that we can.
Contact Support
