You can turn the Arlo Baby night light on and off with a button on the side of Arlo Baby or by using the Arlo app. You can also use the Arlo app to perform the following actions:
To turn the night light on or off with the night light button:
Press the button on the right side of the camera to turn the night light on or off.
To turn the night light on or off from the Arlo app:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
The Devices page displays. - On your Arlo Baby camera feed, tap or click to access the night light controls.
- Tap or click to turn the night light on or off.
The night light stays on until you turn off the night light or until the timer completes if you set a timer.
To adjust the night light’s brightness:
- Tap or click to open the color selection screen.
- Drag the brightness slider to the right to make the night light brighter or to the left to make it dimmer.
- Tap Done or click Close.
To set the night light color:
- Select Colors or Whites and choose a color.
You can choose one of the recently used colors at the bottom of the screen or choose from thousands of colors on the color wheel. - Tap Done or click Close.
To turn on a multi-colored light show:
- Tap or click Light Show.
In light show mode, the night light changes color automatically until you turn off the night light or until the timer completes if you set a timer.
For more information about setting a timer for the night light, see How do I use the timer for my Arlo Baby night light?.
