By default, the Arlo camera Battery Fully Charged LED is set to on. If you do not want the LED to illuminate when the battery is fully charged, you can turn it off in the Arlo Secure App.
To turn the Arlo camera Battery Fully Charged LED off:
For the Arlo Secure App experience with Feed:
- Launch the Arlo Secure App.
- Tap Devices.
- Select your camera.
- Tap .
- Tap the camera name at the top of the Device Settings screen.
- Tap Indicator LED on the Device Info screen.
- Tap the Battery Fully Charged switch to toggle it to the off position.
For the Arlo Secure App experience with Library:
- Tap Settings.
- Tap My Devices.
- Tap Camera LED.
- Tap the Battery Fully Charged Indicator switch to toggle it to the off position.
Last Updated:05/09/2023
Article ID: 1200780
