Arlo Baby comes with a playlist of 10 lullabies, white noises, and nature sounds that you can play with a timer for a duration that you set. You can add tracks from the Arlo Cloud Library or add recordings of your own voice to the playlist. You can also delete tracks that you don’t want from the playlist.
Arlo Baby has limited storage capacity for sounds and music, but you can download tracks from the Arlo Cloud Library for free at any time, including tracks that you previously deleted from the Arlo Baby playlist. If you delete your own recorded tracks from the Arlo Baby playlist, they are permanently deleted.
To add a track from the Arlo Cloud Library:
- Launch the Arlo app or log in to your Arlo account at my.arlo.com.
The Devices page displays.
- On your Arlo Baby camera feed, tap or click to access the music player controls.
- Tap or click to access the playlist.
- Tap or click the + icon.
- Tap or click Download from Cloud Library.
The Arlo Baby Cloud Library page displays.
- Tap or click next to the track that you want to download.
If your Arlo Baby does not have enough storage available, you must delete a file before you can add another file.
The new track is added to the end of your playlist.
To delete a track from the playlist:
- Tap or click Edit.
- Select the check box next to the track that you want to delete.
- Tap or click Delete.
A confirmation message displays if you are deleting a track that you recorded manually.
- If prompted to confirm the deletion, tap or click Yes, Delete.
The track is deleted.
For more information about the Arlo Baby music player, see the following knowledge base articles:
