Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Top Contributors
Temporarily suspend video and audio recording
It would be nice to have a mode called "Temporarily Suspend" that disables the current mode for a set period of time (30 min, 1 hr, 2 hr, etc).  This would allow a user to turn off all cameras but they would automatically return to the previous mode after the set period of time.
273 Comments
I also came here to suggest this.  It would be a very useful feature.  Thank you!
This is needed! Hello. Such a simple feature
Motion not working
Motion not working
Onlooker
How is this feature not implemented yet? It will take a developer max one day to do this. Just do it. As people say. If you know you Will trigger the motion you want to conserve battery by turning it off...but as we are humans, we tend to forget to turn the cameras back on which defeats the whole purpose of having the cameras in the first place.
Observer
Friendly PSA...
If you have kids home from school today, you will most likely have to manually change the mode of your Arlo system.  Don’t forget to re-arm tomorrow!
I could use some help hammering away at this issue.
Novice
Couldn't agree more. I have my camera set up on a front porch and sometimes I like to sit out front and relax. The camera will end up recording all of my motion. And it's easy to forget re-arming (and that's an extra step anyway).
Novice
In the camera device settings located in the app, rather than just being able to toggle the camera "on" or "off", I would like a "temporarily off" option with a selectable time range.
If I'm going to be active within the camera range and don't want constant alerts I would turn the camera off and not always remember to turn it back on. I would like to be able to turn it off for a selected time (from 10 minutes to several hours) after which time it would turn itself back on.
Yes I agree, that would be a nice option.
Another vote for this feature. Would make it even more useful if it can be accessed via the Force Touch menu (which, by the way, is STILL BROKEN).
