× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
SSID name change/disable
We should be allowed to change the name of the SSID to something that isn’t labeled Arlo so we aren’t advertising we have cameras hidden around our residence. This isn’t asking to make the base stations network to be invisible. Just allow us the ability to change the name to something else so no one is aware that a house has cameras.
Comments
Manolo86
We're the only dummies to use Arlo in the neighborhood. The cameras and doorbell are a dead giveaway. It would be nice to make it just a little more difficult for someone to know which SSID is Arlo's.
hipphop
James, because I don’t live in a crowded neighborhood - just a few houses. A burglar could figure out it is my house extremely easily
Bjorr
Arlo should give us the option to disable it after setup.
i have many wifi relays/bases from alot of different companies, that use its own wifi during setup what if they all broadcasted there individual SSID after setup 🙂 id have 20-30 different SSID broscasting around the neighborhood! Arlo is just poor design and people need to stop defending this stupid **bleep**.
Bjorr
What tittle says.
Thank you very much.
joeCHICAGO
Fledgling
allow user to change the ssid name for base station or factory default a diff name that is not so obvious “ARLO” in the ID name.
Twobit
Novice
Please create a tool to disable WiFi broadcasting. I know this has been requested in the past and the response is to the effect of "A hacker with a snooper can find your WiFi so why bother". I don't want an ordinary (non-hacker) know I have Arlo cameras. This just makes it one step easier for someone to break into your system.  Arlo needs to create tool to disable broadcasting.
