- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Multiple subscriptions per account
Idea Options
- Mark as Read
Status:
New Ideas
Submitted by
Thinkbigger
on
2019-08-09
04:01 PM
The way the current subscription system is organized a user is punished for adding more cameras onto their Arlo system. For example I have a 4 camera ultra setup and I wanted to add two baby monitors. I thought that keeping in the Arlo family would be best so I purchased 2 Arlo baby. That has proven to be a mistake because the subscription only allows me to have 5 active cameras .... yes I have to disable/deactivate an ultra camera to use both Arlo baby monitors. To me this makes no sense. One option is to allow my account to have two separate subscriptions. A basic plan for the Arlo baby and the smart plan for the ultra. Honestly I don’t even care about cloud recording so even if there was a single plan that allowed all camera to stream but limited the number of cameras to save to the cloud that would be tolerable. The right solution is to encourage users to add into their Arlo system so there should be no limit to the number of camera supported by a plan or account. If you want to maximize the amount of dollars you get from any user, charge for adding additional features (longer cloud retention, higher quality cloud recording, etc) don’t try to extract more monthly dollars from a user that has already spent money on additional cameras.
As a parting thought when I contacted support with my concern I was encouraged to create two separate Arlo accounts and then link them with the “grant access” function. This just adds additional complication to work around what should be a simple fix. Please don’t hesitate to reach out to me if you want more details
See more ideas labeled with:
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Idea Statuses
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
