Idea Options
- Mark as Read
Integration with various smart home hubs
Status:
Partially Implemented
Submitted by
ralphborrelli
on
2015-07-17
09:23 AM
The whole idea of the smart home is to make it easy. I have my lights, thermostat and door locks all controlled/viewed from one app. I use the Wink system, which I've been very happy with. Currently it only supports the dropcam or nest camera. Arlo has so many opportunities you are missing by adding the additional partnerships or integrations suggested. You could be the #1 system if you added some of the more popular suggestions.
Comments
- 2
- 3
- 2
- 3
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
