Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Top Contributors
Great product but a lot of room for improvement
I've been using this product for 2 weeks now and I believe is a great product but have a lot room for improvement to make it a much better system. This are my suggestions/ideas so hopefully Arlo team can use them to (in my humble opinion) would make this system awesome.
- Integration with IFTTT.
- GPS fence to trigger modes on-off (this would be much easier with IFTTT integration)
- Notification center widget where 4-5 buttons are there to select the Mode without the need of opening the app.
- After motion detection give the ability of keep recording until motion ends. A time limit can be set for battery conservation purposes.
- Make Purchase Cameras link/block on Cameras page less intrusive.
- Give other accounts administrative privileges on Friends section.
- While performing Motion Detection Test show indication on the app when motion is detected.
- Select sections of the video feed to set boundaries where motion detection is triggered or bypassed.
- On camera settings add a button to reset Pan & Zoom.
- Ability to change FPS recording. This probably would save batteries.
1 Comment
Status changed to: Archived - Not Enough Votes
