Geolocation / IFTTT custom modes / improvements
Hi,
I am genuinely excited to see geolocation and IFTTT has been implemented, and yes I know its still 'Beta' but while it is still work in progress i would like to suggest a couple of improvements....
1) You need to support multiple devices. it makes no sense to have the cameras arm as I leave for work, only to get tons of videos of my wife leaving 10 minutes later.
You need to check for all devices to be out of the area before arming the cameras.
2) It should be possible to schedule 'geolocation' control.
Currently geolocation cannot be included in the schedule, which means i need to change the mode manually if like me you set them on during the night when you go to bed.
3) IFTTT - support 'custom' modes.
Currently you can only choose the standard armed or disarmed modes, you need to include for custom modes as well as being able to select gelolocation mode..
This would mean you could use the 'do' trigger to change mode quickly, helping to ease the pain of issue 2.
Overall though i have to say i am impressed with the additional functionality, but please Netgear, keep us informed of what you are working on!!!!
Kind Regards
Nick
Comments
Dumdidum
"Although that may still break when they finally force me onto to 2FA"
Which they will by end of this month!
It will break a lot....
Maverick2805
Fledgling
A kit for 1000$, a monthly fee of 15$ and I can't even connect my custom modes to IFTTT?? Are you serious?  This has been asked for since 5 years and still ain't possible? I really should learn to read forums intensely before buying such rip-off products which is also killing my before flawlessly working wifi... disgusted
