Idea Options
- Mark as Read
Custom Alert Levels
A useful addition to the Arlo App would be to allow different levels of alert. For example you could set up a notifaction alert if someone approaches your house from outside with a simple chime on your phone, you could then have a high priority alert which could trigger if movement is detected inside your house while the system is alarmed, this would obviously need to set off a more attention getting alarm on your phone.
Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
