- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Cross Triggering Cameras With Activity Zones Set A...
- Mark as Read
- Email to a Friend
Cross Triggering Cameras With Activity Zones Set And Have The Recordings Saved To The Cloud/Library
Below the line (bottom of this post) is a reply from Arlo Moderator ShayneS on an issue that I posted on the community boards (I also got the same reply from support, who suggested posting it here) ....
Here is a link to that discussion which explains the issue better and you should read (only 10 posts)... https://community.arlo.com/t5/Arlo-Ultra/Cross-triggering-will-activate-lights-amp-cameras-but-not-s...
This problem (or non-feature) really needs to be fixed as it is mentioned nowhere in the Arlo product info and therefore that info becomes very misleading.
Thanks,
Paul
_________________________________________________________________
As you noted above "What I did confirm was that ALL cameras can be triggered by ALL devices but ANY CAMERA THAT HAS "ACTIVITY ZONES" SET, even though triggered, WILL NOT SAVE THE RECORDING TO THE LIBRARY/CLOUD"
This is feature is by design, if you would like to have the recordings saved to the library you will need to remove the activity zones.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
79 -
Arlo Audio Doorbell
34 -
Arlo Video Doorbell
Arlo Security Light
19 -
Arlo Pro 3 Floodlight
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Q Series
Arlo Essential
Arlo Essential XL
