Solar panel power for cameras
It would be great to be able to attach solar panels to the cameras for more perment installs to charge the batterys.
Comments
chrlybrown
Novice
This is just common sense and with all the technology we have at our disposal, it should not be an issue to make it happen!
MBISHS
There is another parallel posts that discusses customer desires for external power (below).  I suggest that we put all requests related to this topic on one post so that we can aggregate all of the Kudos for the developers.
"Arlo cameras that use a power adapter instead of batteries"
ronnedith
Fledgling
Wouldn't that be easy to develop? The only thing we need to do is to find out the power consumption of the camera, drill a little hole on the camera (where the batteries go), channel the two cables (Positive and negative) and connect it to a solar panel!
This idea could also work for having your camera always connected to an outlet. 🙂
We just need to engineer the correct power consumption and bam! we are done.
What do you guys think?
TazHawaii
Aloha Everyone
Due to Federal shipping regulations, finding a reliable supply of replacement CR123A batteries in Hawaii has become an issue. Is there an alternative battery that can be used other than a Lithium solution, even if it has a lower life cycle charge?
TazHawaii,
NETGEAR does not officially advise the use of any batteries other than what is described in the following article: Remember these golden rules for your Arlo camera batteries
With that being said, there are many threads with discussions surrounding batteries such as: https://community.netgear.com/t5/Buying-Options-Tips/Rechargeable-batteries-for-use-with-Arlo-camera...
I hope this helps!
TazHawaii
Sorry JC, no go....These rechargeables still have the Lithium component. I need a solution that does not include Lithium type batteries. If what you're saying is true, then in about 6 months I'll have a $700.00 security system that will be of absolutely no use to me due to the lack of available power source.
Nice......
Status changed to: New Ideas
Great Idea! Thanks for sharing!
RocketAngel
Really like this one!!!
tpd866
Fledgling
Ive been going through batteries pretty quickly on my two ARLO camera outside. I would love to see a solor panel upgrade for the cameras.
