Bird Prevention Skin
I find Birds land on my Pro cameras which causes two problems.
Poop. Do I need to say more?
When they push off to fly away it changes the view angle on my cameras mounted with the VMA4000 mounts.
Could a silicone skin be made that has a bunch of thin silicone fingers pointing up? Similar to the hard plastic or metal ones you see on top of light posts.
Comments
If that is the case , you still need a screw in mount that locks down to prevent movement... then just put some hardware cloth at the top
kebs
HAHAHAHAHAH
Sorry, that's super hilarious. Get an auto owl
Rickenator
I know I know,
It sounds silly but I’m sure the Arlo skin with the grass covering sounded silly at first also! 🙂
You could have said, “Just glue some grass clippings to the camera.”
I think it could be a source of revenue for Netgear.
