Idea Options
- Mark as Read
Arlo Q - Direct Connect (Baby Monitor)
Status:
Implemented in latest product
Submitted by
Remlam
on
2016-06-02
07:19 PM
I am going to suggest a great much needed idea. Please support this so that netgear implements. Currently there is much lag when operating the Arlo q in live mode. So much lag that is makes live mode pretty much useless for monitoring a baby. Currently I have a 5-10 second delay in live mode and am connected at 60Mbps. The reason for this is that connecting through the netgear servers adds the delay to what you see on your device.
This is very easily solved my a minor enhancement. Arlo needs to be updated to allow a direct connect feature where if you are on the same network as Arlo q (home) you can enable from your smart device to connect directly to the Arlo q bypassing the servers. This would allow true real time live mode and ability to truly see if your baby needs help now (not 15 seconds ago). Arlo could name this feature "baby mode". Not very complicated with great benefits!
While in live mode (baby monitor mode) it would also be great if motion detection could be enabled and alert (ie you are watching your baby sleep in live mode. You don't want to stare at the screen for 8 hours so it would be nice to have an alert when baby moves in live mode.). Using the motion activated recording is useless for this. Takes to long to connect in to live view.
What I am asking for here can be used not just for baby monitor but other applications as well. It is such an easy change that I'm sure if others backed the need for this netgear would respond. It is in their favour since it will open them to the baby monitor market with a camera that can be used after the baby grows up as a security camera. Currently, it is a lawsuit waiting to happen where someone misses their baby choking by the 15s delay. You catch my drift. Thanks for listening.
Comments
- 5
- 6
- 7
- 5
- 6
- 7
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
