- Community Home Home
- Community Browser:
- English
- Arlo Forum Discussions
- Arlo Idea Exchange
- Arlo Go access SD card storage remotely
- Mark as Read
I received an email from netgear saying one of my Arlo Go cameras went off network for a while and the camera recorded an event to the camera's SD card. I was surprised to find out that I cannot view the recorded event thru the Arlo mobile app library feature once the camera came back online. After contacting the Arlo Go technical support, the rep says the only way to view the event is to go to the camera, remove the SD card and view with a computer. Given this camera was designed with the sole purpose of operating wirelessly (power or communication) in remote areas it seems like a major oversight to not allow access to the SD card via the Arlo mobile app once the camera is back online. Not a completely thought out design if I have to frequently drive to a remote location in order to access the camera footage. Only had Arlo Go for 4 months. Hopefully this doesn't start happening often. Would think the camera should be able to read as well as write to the SD Card. If so then a firmware update to the camera and software update for the Arlo app should be all thats needed.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Arlo Baby
78 -
Arlo Video Doorbell
34 -
Arlo Audio Doorbell
33 -
Arlo Security Light
Arlo Pro 3 Floodlight
15 -
Arlo Ultra 2
Arlo Pro 4
Arlo Essential Spotlight
Arlo Essential
Arlo Essential XL
