Arlo Doorbell Custom Ringtone
Is there anyway to change the ring when someone pushes the doorbell?  It rings my normal phone ring.  I can only seem to customize the motion notifications.
Comments
rasmith2210
Fledgling
When my doorbell rings it has the same ring as if someone is calling me. I want to change that. Also when it notifys me that it sees movement it sounds like a text message. I want to change the sounds to something different and can’t figure that out.
austiamel47
Novice
Does anyone know how to change the ringtone when the doorbell button is pressed? (Or a work around or hack?) It rings my default ringtone and it would be nice to know if it's my doorbell by the ringtone.
Also, has anyone figured out how to use Alexa to set a routine that will notify of motion? I can only get a notification to me Echo Show if the button is pressed. I can set up motion notifications to play on the Show, using a routine for my Arlo Pro 2.
Thanks in advance!
