Add the Arlo Doorbell To The Smartthings Integration
Please make the Arlo Doorbell available in the Smartthings integration
Comments
rbarbeau
Novice
Please make it compatbile with Smartthins and I will buy your doorbell!!
GenericArlo
Fledgling
Really want it to work with smartthings.
Kainax
Fledgling
Please make it posible! I purchased it for smartthings integration but found that only arlo camera sending montion event to smartthings. I expected doorbell to send the following events to smartthings:
1. Doorbell motion detected event
2. Doorbell button press event
Optional events:
3. Low battery
4. Doorbell called to phone
5. Phone conversation started
6. Phone conversation ended
Optional commands:
1. Play Doorbell sound - default or custom? (could be used as a feedback for automation scenes, for eample to indicate that remote cameras are armed, or to inform backyard intruders about detection of their pressence to scare them)
Thanks a lot.
Sinkle
Fledgling
Please make the doorbell work with SmartThings
jabdelh2
Novice
This doorbell is useless for me since it doesn’t work with SmartThings. Best Buy employee told me it would. Can’t return now because it’s been too long since purchase.
Seajayvee
Fledgling
Still waiting for integration! I want to trigger the doorbell from SmartThings like a door sensor opening. I don’t understand why all your other products are SmartThings compatible but your doorbell and ringer are not.
Atemplet
Fledgling
Waiting on this to happen daily....
Seajayvee
Fledgling
Still waiting
Falloon
Fledgling
This would be fantastically useful to alert when all Smartthings sensors are triggered, not just my arlo cameras
Hustomten123
Novice
I would appreciate if you could integrate the doorbell with SmartThings. Useless without.
