glassbreak sensing update?
  • 1 Reply
  • 2090 Views
safehaus
Hi,
Is there anything in the works for adding glass break sensitivity to the all in one sensors? Whether that is a separate sensor or add on to the existing ones. Or are there any companies that offer a compatible product? Thanks!
safehaus,
Arlo All-In-One Sensors have the following functions:
  • Motion Detection: Receive alerts when motion is detected inside your home
  • Open/Close with Magnet: Open and close detection gives you the ability to act when a door or window is opened
  • Open/Close with Tilt: Tilt detection lets you know to check in when a garage door or window is opened
  • Water Leak: Water leak detection helps prevent damage from leaky pipes or water heaters
  • Temperature: Temperature detection alerts you before your pipes freeze in cold weather
  • Light: Light detection alerts you to check in when there are ambient light changes in your home
  • Smoke Alarm Listening: Get the right type of emergency help when a smoke alarm is triggered
  • CO Alarm Listening: CO alarm listening notifies you when a Carbon Monoxide alarm is set off
I do not have any information on glass break detection but I will pass this feedback along to the development team.
