- English
- Services
- Arlo Home Security System
- arlo ultra 2 4k can't install new camera replaceme...
arlo ultra 2 4k can't install new camera replacement
replacing camera and base is not pairing with wifi
Neither the hub nor Ultra camera use your WiFi. The hub is connected via the Ethernet cable and the camera connects to the hub using the hub's protected WiFi.
Are you following the procedure in the app to set up the hub, including connecting both power and Ethernet? Have you ensured the cables are properly connected? What does the hub's LED show after a couple of minutes when the hub is plugged in? It should be solid blue.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
