VMC4060A not stable on VMB5000
Hi, I have a gateway VMB5000, where the following cams are connected:
2 x VMC5040, 2 x VMC3050B, 1 x AVD2001A, 1 x VMC2040B and 2 x VMC2040B.
I have problem with the 2 VMC4060A, the get unresponsive after around 12 hours.
If I the disconnect the battery, and connect it again, they are ok for 12 more hours
If I connect them to wifi, they are ok
Any suggestions ?
Where is the hub relative to your router? Try moving the hub away from the router as far as practical.
It is rather far away from the router, but why do you think it only happens to Pro 5 cams ?
Each camera model (and perhaps hardware revisions within that model) likely has different WiFi chipsets so range could well be different. Since it seems to be a new issue, it could possibly be a new firmware release that changed something (no idea if one was released) but could also be due to some new or moved wireless devices that is causing interference. Are the cameras in somewhat the same location rather than opposite sides of the house? If so, see if you can find something that could cause this.
Have send them back to dealer for exchange
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
