- English
- Services
- Arlo Home Security System
- Unable to Join the Network Arlo_ when adding a Key...
Unable to Join the Network Arlo_ when adding a Keybad Sensor Hub to my Eero 7 network
I am at my wits' end trying to solve this problem (have talked to support at level 1, level 2, and some other level for over 12 hours now) but here is the issue:
I have a keypad sensor hub. I'm trying to install it at my office, which just has a normal commercial internet connection. I have an Eero 7 mesh system, and I've even unplugged the satellite to just see if it would work.
Every time I go to add the hub device, it has the message that says
"Unable to Join the Network Arlo_2409"
- I was even told to go return it and buy another hub, which I tried, and it had the same error.
- I have paused the 5 GHz network and am still having the same issue.
- I tried a D-bit 2 GHz router to see if that would work, and it did not.
- I took the keypad sensor hub to my house, and it actually worked FINE (and that was an Eero Router 6)
- I've literally done every possible troubleshooting step you can find for what to do. If you're going to ask about it, I probably have done it unless it's something that has not been mentioned in all of these forums.
I have no idea what to do at this point. Does anybody have any ideas?
@JamesC you seem to have a lot of answers. concerning this issue. would you be willing to look at my issue and give me some direction?
@ryanadams23 wrote:I took the keypad sensor hub to my house, and it actually worked FINE (and that was an Eero Router 6)
Did you try temporarily setting this wifi to match your corporate network SSID and password? Then do the install, power down the hub and move it back to the office?
Are you using the same device to do the install at home as you are using in the office? What device is this?
This is a keypad sensor hub. get to my home and it connected to that Wi-Fi perfectly.
it’s not working at my office router, which is the same router as my home one, but with just a different name. tried renaming the network at my office the same as my home, and that didn’t work either.
they had me get a new one, and it still doing the same thing
Please reach out to support, they will look into this further.
US/CA Customers - 1-877-427-5680 6:00a.m. - 8:00p.m. PST
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
