Notifications for sensors
All in one sensors are not sending notifications to my phone - I only get the ones for light and motion not door opening or movement or smoke alarm - they all appear to be set up the same
Message 1 of 2
878
Have you verified you have the modes enabled in the sensors settings and rules set for the door opening/send notification?
You can find more info here: https://kb.arlo.com/000062791/How-do-I-install-and-configure-my-Arlo-All-in-One-Sensor-as-an-Open-Cl...
Message 2 of 2
869
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
