NC
Is anyone else getting this? Something wrong with Arlo secure....
What were you trying to do when this happened? There have been reports of the latest app (5.4.0) crashing if you use Library to view recordings and then pick Local to view local recordings on a hub.
Yes. That is exactly what I am trying to do....
Thanks for reply.
Right now it would seem that you need to wait for a new version to be released. You could migrate your account to use Feed instead of Library but there are ramifications around doing so, such as losing custom modes as well as needing to check all modes for proper rules, schedules and geofencing settings. If your setup is relatively simple, it shouldn't be much of a transition other than the look and feel and where things are located.
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
