I cannot factory reset my system. I have tried the instructions in Arlo support to factory reset. When I try to connect the system back on the app it won’t connect
Did you first remove it from your account before resetting and attempting to add it back?
Yes I did that. It won’t connect when my phone prompts me to join the Arlo WiFi network
Verify that the phone settings allow you to connect to unknown open networks.
Did you hold the Check mark button and the X button for 15 seconds to hard factory reset it after you removed it from the application?
Also after factory resetting unplug the power supply for 10 seconds then allow it to boot back up and try to onboard it again.
External Arlo Tester
I didn’t unplug after doing the 15 seconds holding the check mark and X button. Will try it and see
Thank you
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
