- English
- Services
- Arlo Home Security System
- Re: Geofencing for Cameras on new Home Security Ap...
Hoping someone can help as this seems way more complicated than it should be. I have older cameras and hub that were running just fine set on geofencing for years. I just got the home security system and therefore was forced to upgrade to the new app. When I did so the geofencing turned off for the cameras and i cant figure out how to setup again. Basically what i want is for the cameras to operate on geofencing but NOT the security system. Want cameras to arm when i leave even if the alarm is on standby, and I want the alarm to not run on geofencing so only armed if i turn it on myself. Anyone know how to do this please help!!! I'm lost in this new app.
If you want the cameras and the security system to be completely independent, then the easiest way to do that is to set up another account for the cameras. Then share the cameras with the home security system.
You will end up on the new interface for both accounts.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
