- English
- Services
- Arlo Home Security System
- Re: Base station - VMB4540r2 Camera - H10 - remot...
Camera - H10
This camera has lost connection to the base station (battery is fully charged) - other cameras are fine.
As I am away from the site, I cannot reboot the camera. If I select remote "Restart" on the Base Station menu, do I also lose all camera connections to the base station? I have five cameras active, so cannot afford to lose access to other cameras. Will I lose connections on restart of the Base-station?
Rebooting the hub doesn't normally cause disconnects from any camera - they should reconnect automatically when the hub is back online. That said, there's always a chance something can go wrong but I've never had that happen. YMMV
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
