- English
- Services
- Arlo Home Security System
- Automations in new app - I cannot get automations ...
Automations in new app - I cannot get automations to reliably work
I cannot get automations to reliably work for a custom schedule. The cameras are more often off than on and seem to come on when they like. The new app has a horrendous interface that I can’t get to work and I presume is designed by someone who never leaves home. The old app was flawless and easy. It appears at this point of time I have wasted my money. Any surggestiosn?
Arlo app
The biggest thing to know about the new schedules is that you need one to start a time period and then another one to start the next one - you don't ever "stop" a period. So, let's say you want all cameras armed at 10 PM and then only certain ones at 7 AM. You can use Arm Away for the nighttime schedule and Arm Home for daytime. Arm Away automatically gets all cameras added to it but no other mode does so edit Arm Home to place appropriate rules for the needed cameras in there. Then set up the schedules with the nighttime one changing the mode to Arm Away and the daytime one to change to Arm Home. If you just want all cameras off, choose the Standby mode to change to and verify that it has no rules in it. Here's an FAQ that may help:
https://kb.arlo.com/000062942/How-do-I-add-a-Schedule-Automation-to-my-Arlo-system
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
