Arlo mobile ohone
  • 4 Replies
  • 500 Views
CATTWOMAN33
I accidently deleted my new phone as a trusted device and I cannot add it as a message showz something went wrong. I tried every verification step,unistalled and re installed it and nothing. My new phone is a Samsung Zfold 8.
Van somebody help please? Thanks
CATTWOMAN33
Apologies for the delay in replying to your message.
Problem solved.
Thank you
Try using a computer browser to go to my.arlo.com and check Settings, Two-Step Verification. Can you delete old devices there?
CATTWOMAN33
Thank you for your reply. I tried that,but still cannot get to trust my new device. Maybe something is  corrupt and that is the reason.
Regards
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
CATTWOMAN33
Problem solved.
Thank you
