Arlo Water Leak Detection
Good morning. This is more of a suggestion than a question. I recently had a broken pipe flood my basement and I have the Arlo Security System with the leak sensor ability, however there is no automatic water shut off valve or adapter offered by Arlo. I would have to buy a standalone or another system to get the automatic valve shutoff. Is this something that has been considered by Arlo? If not, I would like to make a suggestion for Arlo to create an automatic valve shutoff or allow a third party device to be integrated. This would offer a complete water leak protections. As it stands now all it will do is notify me, but if I'm not home that does not help me shut off water to prevent flooding. Thanks.
We appreciate your suggestion regarding a automatic shutoff for the water if it detects a leak. I have reached out to our development team and let them know about this feature request.
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
