Hello,
I have recently ordered the Arlo Security System. I have other Arlo cameras and doorbell already and the most updated version of the app.
However, when I go to see about adding the system, the app does not give an option for Security. Only cameras, lights and doorbells and base station.
Any ideas?
@TCLIII wrote:I have recently ordered the Arlo Security System. I have other Arlo cameras and doorbell already and the most updated version of the app.
What country are you in?
Outside the U.S. But have VPN and wanted to use this without monitoring subscription. Just to monitor doors/windows.
I have the U.S. version of the app.
The app itself is global.
Do you mean that the account you are using was created in the U.S. (or created using a VPN that terminated in the U.S.)?
Created using a VPN that terminated in the U.S.
Also went to the portal via web browser and same options. No option to add security system or even Pro5 cameras available.
Looked around and nowhere did it specify my location or account creation location.
Arlo is available in the following regions: https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
Accessing Local Storage
Arlo
Arlo app
Arlo Essential Spotlight
Arlo Pro 3 Floodlight
Arlo Pro 5S 2K
Arlo Secure 4.0
Arlo Smart Hub
customer service
door sensor
Eero
google
home
Keypad
Keypad Sensor Hub
mode
monitoring
Mount
MS1001
No Sound
old feed
PIN
Primary PIN
Public Key Required
RMA
Secondary PIN
Security Keypad
Security System
Security System App
Sensor
Setting-up
Siren
support
System
Test Mode
Total Security Package
update
Wall
Website
