camera was offline for 1744 seconds and no events were recorded"
Is anyone else having issues with Arlo device being offline? mine had been disconnecting and would come back after a minute or two, now it's not coming back online...
last time it was over an hour offline, get a nice little email after the fact, now it's started doing it again...smdh
You mean the base?... Have you rebooted it via the power button ( off then on, give a few mins to fully come online )
No it's an Arlo Go mobile, connected thru my mobile service provider. Keeps going offline for a while then it'll come back online, after which I recieve an email from arlo stating "Your Arlo Camera, is reconnected to the network. The camera was offline for 1744 seconds and no events were recorded" . I find this quite annoying.
also the device is 3 hrs away from my location, not so easy to push a button a reboot. It has a solar charger so I know that it has plenty of battery life.
Here we go again....this is really fustrating
cshepherd1,
Which Arlo Go provider are you using? (ATT, Verizon, Arlo Mobile, etc.). It's possible, there could be a provider outage at your cameras location that is causing an issue.
Are you still experiencing this behavior?
JameC
Modes et règles
