My solar panel don't work anymore. Shows a yellow triangle with lighting symbol.
  • 1 Reply
  • 1336 Views
Riikka
I bought solar panel couple years ago and it have worked very good with my Arlo Go until now. About week ago my Arlo Go battery starts to indicate low battery level and there is yeallow triangle with the lightning -symbol in device settings. The temperature haven't been extremely low (about 10...15 Celsius).
What happend? What I can do?
I would pull the panel and verify the contacts are clean ( where it plugs in ) and do not have any crud in there.
Also, if you have a multi meter, you can check the output of the panel at end of connector. In sun, the output should be just under 6v (IIRC) ( will need small wire to access pins )
  • 1 Reply
  • 1337 Views
