Just got a charging station
(VMA4400C) and I noticed that when I charge the batteries with this charger
The level gets stuck at 100%
The only way to fix it is to remove and reinstall battery couple of Times
Which is not very convenience
Think of it like when you use the Charge Tube, you get 25% more battery life before it starts to go down in the meter
I assume you mean after installing the battery in the camera it gets stuck at 100%? Are you aware that charging in the camera is really only to 80% of the battery capacity so you don't over-charge the battery when on AC power? The display shows 100% but it's 100% of that 80%. When charged in the external charger, there's no such protection - it charges to a true 100%. When installed in the camera, the display is still at 100% of that 80% - it takes a while to discharge to the true 80% so the display will start showing what's normally expected.
I know this sounds confusing - speak up if so.
I will check if the level percentage goes down after a while
I know it didn’t after two days so I remove the battery put it back and I went to 98%
How fast it gets to 80% depends on how many recordings and how much live view you're doing as well as signal strength/quality. Mine lasts weeks before starting to report anything less than 100%.
When I called Arlo tech support they had no idea
Modes et règles
