  • 1 Reply
  • 1552 Views
devalc
Hi,
I plan to buy Arlo Go and ship to Taiwan.
Can I use Arlo Go in Taiwan? If yes, could I use Solar Panel Power Supply in Taiwan?
Thanks very much for your help.
ShayneS
Hi @devalc
Q. Can I use Arlo Go in Taiwan?
-A. I have provided a link with more info with purchasing an Arlo GO for use in Taiwan. Link Here: How can I tell who my Arlo Go service provider is?
You will need to make sure you purchase the camera with the correct SKU for your Service Provider. The link will provide information for which service providers are supported for each sku.
Q. If yes, could I use Solar Panel Power Supply in Taiwan?
-A. yes, the vma4600 solar panel is compatible with arlo go
  • 1 Reply
  • 1553 Views
