Blue flashing light - Arlo Go
hi, my Arlo go has a constant blue flashing light on it and it won’t let me connect to the Arlo app. It’s got a subscription, battery charged etc. Any suggestions please?
Try the reset procedure - any better?
https://kb.arlo.com/1202749/How-do-I-reset-my-Arlo-Go-camera-to-factory-default-settings
My advice is only if you have an Arlo subscription plan:
You aren't connected to a data plan yet. You need to call Arlo and ask for some free minutes. Once they give you those minutes you can connect and then purchase a subscription.
Modes et règles
