Arlo go with vodafone won't scan QR code (VML4030)
Hi
I have an Arlo Go and a Vodafone V-Sim (in the UK). The sim is active and when I insert and power on the Arlo Go it chimes and the led is blue - which I believe means that it has connected to the mobile network.
However when I try and scan the QR code to connect to the cloud it fails, I get a rapid flash orange light and the fail sound...I have tried multiple times, I have tried to factory reset the Arlo Go, I have even waited 1 day...but I am still unable to connect.
Please help
Hi @lotuska
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Modes et règles
