Got a couple of questions on the arlo go.
1. Can the CHARGING cord be used to power the camera via 110v power or do you have to buy an additional electrical cord?
2. Does the arlo go need a specific type sim card other than carrier specific?
3. If I don't have a sim card can I just buy one at Walmart and activate it myself? If so how do I go about activating it?
You can charge the Arlo Go with the included power supply/cable. The Arlo Go was available with specific sim/carrier requirements. You must use the sim provided by Arlo or the carrier you purchase the Arlo Go camera from.
Modes et règles
