Arlo Go schedules not working since update
Is your timezone set properly?
suasnpd,
If you schedule using the mobile app, do you experience the same behavior?
Sorry, same account, different user name. I'm having Arlo support site issues as well. Yes, I have reset the schedules using both mobile and desktop and same problems. In fact, mobile and desktop often show different schedule statuses when viewed. The cams will show schedule disarmed, but continue activating or they will show disarmed, but per the schedule supposed to be active.
I've had the same problem for the past 9 months and I've spent hundreds of hours trying to troubleshoot it. I've given up on this issue getting resolved. Now I just manually activate/deactivate the cameras every night/morning. Hopefully Ring will release a similar product that actually works soon so we can just throw these out.
Yeah, my updates to support are getting less kind. We shouldn't have to wait 6 months for them to fix this like we did the recent AT&T offline cameras bug. The cameras are not abiding by the schedules despite the schedule status, the schedules are not switching at the appropriate times, and schedule statuses on the mobile and the desktop aren't matching up, and now I've also discovered despite turning off all notifications for the cameras my folks with access status are STILL receiving notifications.
My support requests are getting nowhere. I have done EVERYTHING they have asked numerous times and all 10 of my original Arlo Go cameras have the same scheduling error - they don't work consistently. I'm at the point I want my money back. I spent $4,000 on 10 cameras and this is a network/software glitch. Not a camera hardware issue. I am generally a nice and patient customer, but there has been no response to this issue and I AM NOT HAPPY. Is there someone you can escalate this to?
test2,
I will review your open support ticket and escalate as needed.
Any update on this annoying issue? When will it be fixed?!?
My #GO camera is still not working properly, scheduling is still ignored or it is activating/disabling on anything else but not my schedule, maybe depending on the weather?!
That‘s really embarrassing!
Orla-Resu,
Have you completely deleted and recreated the schedule?
Modes et règles
