Where Can I get the Arlo GO charging station, or will the arlo pro charging station charge the arlo go batteries.
The Arlo Pro charging station will also charge Arlo Go batteries. You can take a look at the Arlo Pro charging station here: Arlo Pro Charging Station (VMA4400C)
It talks about it in the owners manual as well as on the website. But I haven't found a place to order it either. Thus my question as to is the arlo pro the same charger for the Go. I saw the Go is higher capacity. I am fixing to mount my camers in a remote location on our land and have ordered a 2nd battery. But how am I supposed to charge it so that when I visit the land I cn just change out the batteries. Charging it from the camera is not an option since it is remote.
Anybody have any ideas as to when or where they are coming out with the charging station for arlo go? or if the arlo pro charging station works on the arlo go batteries??
Its very possible that the charging station will accept batteries from both the Go and the Pro.
Like you, we all waiting with baited breath for the product to hit the market.
I doubt the Pro charging station will accept Go batteries which are a higher capacity and have additional cells. It physically won't fit.
The Go battery would absolutely fit into the charger it would just stick out a bit. They both have the same charging voltage the Go is just higher capacity.
Hopefully we'll find out soon.
Modes et règles
