I have an arlo go camera at a second home, it always goes off line. How do I get it back online if I am physically not there
Only the base can be rebooted remotely...
If the camera is offline , there is nothing you can do.
Two things I recommend for away locations;
1) throw a UPS on the base unit ( add modem, router ) this keep the system up during power failures so the cams don't go offline
2) look into maybe a Q camera that is ac powered ( indoors ) that auto resyncs when the power/wifi comes back
It's a Go camera so no base. It may be that your minutes have run out - have you verified? If the cell connection has dropped for any reason the same thing will happen.
My arlo go just went offline and I don't know how to get it back online. Also I don't seem to be able to record more the 10 seconds. There is no SAVE button when I try to move to 2 minutes
Thanks for your help
Is it possible that you're out of minutes?
When setting the recording time from a browser, use the Edit Rule link at the top. For the app, use the Back link. Save is on that screen.
Modes et règles
