Arlo Go Sim Options - Tests So far
Since We're all trying to get these cameras to work after Vsim was shut down, i thought i'd share what i've come across
- O2 Pay monthyl Sim works without any config (chuck it in and it does its thing)
- Vodafone sim : Works but its not plug and play ( Update APN settings to Wap.vodafone.co.uk, username to wap, password to wap). Once you changed the settings then you have to press the power button and listen out for the shutter sound and then scan the qr code and it will start working. (once you update the APN settings the camera takes you through this process)
Intermittent sims
- Tried a RWG sim - This was one off payment sim which either run on 3 or EE, (ran on 3 for me). it was plug n play but it was intermittent, didn work in most places
Hope that helps, if i test any more sims i'll update here
Modes et règles
